Wifi frequently does not connect
The vehicle with the BMS is within range of the home’s Wifi network. My phone is a couple of feet away from the BMS, and over and over again no device is found. Then suddenly, all same conditions, device is found. Anyway to make this more stable?
Hi Lance,
What software and version are you using to connect? (ToolKit2 or the mobile app? iOS or Android?)
What firmware version is your WatchMon running?
How much distance/wall is between your WMC and the router?
Keen to get to the bottom of this one!
Intermittent ‘no device found’ with the phone right next to the unit usually points at discovery rather than signal strength: mDNS/multicast being filtered by the router or an AP with ‘client isolation’ on, band steering pushing the phone onto 5 GHz while the WatchMon is 2.4 GHz-only, or a DHCP lease that keeps changing. Quick tests: split the 2.4 and 5 GHz SSIDs, give the BMS a DHCP reservation, and turn off IGMP snooping/client isolation on that network. It would also help to know whether it fails in both the app and ToolKit2, or only one of them.
