We want your thoughts on our new MQTT capabilities!
Is there any update on capability?
When will this new configuration be visible?
I need to capture the battery’s SOC for security reasons on my system.
There has been no updates in a long time on this subject..
I thought I would share my Home Assistant add-on, it takes the UDP data stream and sends it to an MQTT broker with Home Assistant auto device discovery. Installation details are on the GitHub, Add-on store, add the repository, install, minimal configuration and a device appears in Home Assistant with most of the data. Still some work to do with the longer term statistical data but it’s a start.
Take a look at it on GitHub
Ric
Hi James,
It’s been two years since the announcement of the upcoming MQTT capabilities.
Are there any update on this?
Thx, works prety well.
James
What’s the chance of getting an up-to-date spec for the UDP stream so I can update the add-on to the latest spec’s?
Ric
Thank you so much RKFLYER! Getting all of this in Home Assistant is an absolute treat.
Hi Ric,
Thanks again for your work on this.
My understanding is that for now, the published spec should be correct. If you need clarification on anything or find that it is not working as expected, DM me and I will see what I can do.
Our software engineers are flat out on ToolKit3 and other initiatives, so I may be a bit limited in what I can change, but I will help where I can.
