When the trip occurs, the contact is closed (current flows) suitable for MCCB Shut-Trip
For example ABB sace tmax
or
When the trip occurs, the contact is opened (current is interrupted) suitable for relays
For example EV200ADANA
Can I choose whether current flows or is interrupted?
It sounds like you want the critical rules instead. Simply adjust the CellVolt Hi and CellVolt Lo on the Control > Critical tab to the thresholds you want.
From there, you can use the following options on the Expansion tab depending on your desired operation:
Critical BattOk - This will be active (relay closed) whenever the battery is OK (not in critical)
Critical Pulse Off (CB Trip) - Will be pulsed for a few seconds when the battery enters a critical state
Critical Fault - This will be active (relay closed) whenever the battery is in critical state (and stays that way until it is OK again)
