I get a lot of random bogus voltage detections - for example, when balancing, my cells are rock solid at 4.1v, but every now and then a crazy high voltage of say 4.89v will be detected for a split second. Can you suggest why this is the case, if its a problem and if there is a solution?
Without knowing more about your setup and configuration, you may refer to the suggestion below:
Consider increasing the delay transitions. This applies to Critical, Charging and Discharge:
- Critical stop should be 45 seconds, restart after 120 seconds
- Charging stop 5 secs, restart 60 seconds
- Discharge stop 10 seconds, restart 30 seconds
For better assistance, it’s always best to send the manual extract report. SUPPORT - Manual Extract Report
Also, best to consider a support session if you want a remote session to further assist and troubleshoot the issue faster. PAID SUPPORT
