Unknown Rx integration for imeon inverter
Hi everyone,
I’m in trouble right now because of my integration between my inverter (imeon energy inverter 9.12) and the watchmon core. Indeed, I’ve got plenty of unknown RX and it works for like 4tx and Rx known and unknown and stop working for 5 tx and then restart with 4 Rx known and unknown.
I’m putting imeon inverter in the list of canbus protocol and imeon battery on the inverter software.
Did it happen to anyone and have you got a solution?
I can’t really understand the point and the technic support is helping me through this issue so I’m going to keep you inform about it.
If anyone has also an iron inverter please help me.
Thank you!!
Hi Tom,
You spoke to me via email, and we figured out that you needed to fix your scaling value as mentioned by our wiki, hitting default will correct this :slight_smile:
Hi Tom
What kind of battery have you connected with Imeon and Batrium?
Best regard Micke
It was batteries from AliExpress. No specific brand. Today, I connected a lead-acud battery and it works perfectly except the fact that it’s only 70% efficient. If you try to connect them, maybe my error was because I didn’t authorize the grid injection. Try it if it doesn’t work for you. Also with the Imeon inverter, it only worked with “imeon” on the batrium software and “weco-5k3” on the imeon software. I’m sorry that’s all I know. It didn’t work for me so I bought a lead acid battery.
