From user: m#c1&eL3
Can i connect two ShuntMon´s to one WatchMon-CORE (its connected via CAN to an Victron System)? Or is it possible to make this WatchMon-CORE as Master and connect a second WatchMon-CORE (or Watchmon4 - i have one here) as a slave and connect the second ShuntMon to the slave? The CAN connection to the Victron System should work after the modification. Is this somhow possible? Thanks!
