I have the following problem:
The SMA Sunny Island 6.0 can charge/discharge 4.6kW
When the battery is discharged, both the SMA and the shunt show the same value, maximum 4.6kW.
When charging, however, the shunt always shows a lower value, at 4.6kW only about 4.0kW. Always 10%-15% too low, regardless of the charging power.
This of course distorts the SOC, as the BMS cannot record this correctly.
Is there a solution, is the shunt defective? Is it possible to calibrate something?
Could you share some more info on your system such as pictures of how it is laid out (focus on shunt and inverter), and a Manual Extract?
This will give us a better picture of what might be happening here. In general, do you notice an innacuracy around a certain range of current? or is it everywhere?
