I have a watchman core and expansion board controlling 2 cell mate k9 which will monitor 2 parallel banks of 16 cells each. So I see on the chart view 32 cells. (#1-32).
Can I setup the watchmon core to control one relay on expansion board if one cell #1-16 drops to 3v. And also setup the watchmon core to control a different relay if one cell #17-32 drops to 3v.
Or do I have to have 2 watchmon core?
For now you will need two WMC, as the WMC is in charge of the control logic, but since we are seeing more multi-string or HV systems, so we are working on new hardware to solve this problem.
If you have not built your pack yet, I suggest putting your cells in parallel instead of multi-string:
Thanks, I have 32 300ah cells. I am looking for redundancy, backup, and safety.
I have 2 80amp charge controller to charge the batteries.
Should I use a watchmon core, expansion board, cellmate for each battery bank as 16S1P.
Or am I better off setting up as watchmon core, expansion board, and 2 cellmates. Connect batteries as 16S2P . 2 16 cell banks in Parallel and use the watchmon core to isolate or shutdown an individual bank if there is an issue such as over charging or when a cell hits 3v.
Just to clarify, in reference to the diagrams I posted above, do you mean [2M|16S|1P] or [16S|2P]?
If you want redundancy, yes you will need 2 of everything. Could you elaborate on your needs a little more as to why you need redundancy? Are you completely off grid?
Indeed it’s a LONG awaited feature to have the WMC control more than one relay depending on certain conditions.
Like @Magneticpwr, a lot of users in Europe are having multiple K9s with multiple 16S battery banks.
In case of any issue/failure, the WMC pulls the trigger on one defined relay, separating all battery banks from the bus bar.
Like @Magneticpwr mentioned in his first post, it would be awesome to have one WMC with its control logic being able to pull relay 1 when failure at cell range 1-16, pull relay 2 when failure at range cell 17-32, and so on.
Most European DIY guys like me run a TE Kilovac EV200 (or an ABB breaker with shunt trip) attached to the WMC relay.
Hope that helps to understand the idea/wish behind it!
