Just received my Batrium modules & have a question about the temperature sensor connections on the CellMate K9. The battery bank that I am using has two thermistors already installed, but to save 10" of wire they tied one side of each sensor together (ie, T1, T2, common). Can I use this configuration with the K9 CellMate or do I have to tear into the wiring harness and add a wire to isolate each sensor from the other? Thanks.
