After installing version 54, Wi-Fi connection fails. So far it has been running for 4 years without any problems. With the 54 I configure the Wi-Fi and after a short time the connection is lost and cannot be recovered…….
I’ve got the same problem.
And yes the firmware has been updated.
If I power cycle the WatchMon I can connect ok for a few days, maybe a week, then it drops off.
WiFi is both 2.4 & 5GHz, signal strength I can’t check right now but from memory was good (devices are about 5m from each other).
Happy to help out with some logs etc but I won’t be in front of the device for a few days.
Hi James
My wifi is 2.4Ghz and 5Ghz. Until now it was working well. I have had to change the Wi-Fi to create 2 different networks and it works fine, but for my needs this is a problem. I would like to be able to maintain a single network name with the 2 frequencies like I had before. I hope this is fixed in future versions…
It seems when your router hosts 2.4 and 5 simultaneously, it does not broadcast it’s SSID on 2.4GHz. This means your network will not show up on our list, but you can still connect to it.
Just carefully enter the SSID into the field of the Join WiFi AP tool and it should work,
Had Wifi problems with previous builds, it got worse over time. First dropouts every few weeks, than days. With the lastest beta dropouts every few hours. Sometimes it looked like the connection dropped when suddenly the sun came out and a high load on the batt.
Added a stable powersupply to the WM5, it was running from the 48V batt before. No change
Set up a second 2.4 only wifi (with my 5Ghz AP) (15m away), no change
Bought a shelly to remotely switch on/off the WM5
Set up a new 2.4 wifi with a different old AP 2m away from the WM5, dropouts again
Connecting to my Wifi was not easy, several errors when trying to connect, sometimes it worked within 2 seconds, then 5-10 seconds, or an error.
Then tried another newer AP, again only 2m away, that seems to have solved the problem, works now for > 1 week without issues. The WM5 seems to be very picky which AP it likes or not. All other clients (including several Raspis next to the WM) never had issues
Finally the wifi has failed again, it has been working for several days and it has failed again. Do you have a reliable version that guarantees that I will not have problems?
It’s called band-steering and is an option on many access points to try and move clients to 5GHz. It is not causing a problem for me; however, you can try disabling it to see if it helps.
Oh really? I still have no answer on this matter…
We are talking about a Wi-Fi connection, something basic. I have not been able to connect to the system for several days because the Wi-Fi has not connected since the change to version 54. Since I am remote I cannot use the Wifi AP join function. Can you guide me, give me any solution? This forum doesn’t seem very agile…
Ill be honest when i upgraded a few months ago and tried the WiFi feature i didnt find it to be very good, also it prevented the BMS from using the serial connection. So i do not use WiFi or the APP.
I instead run a mini PC with the toolkit next to the BMS and the mini PC is online and remotely accessible. this is how i manage it
I have this problem as well albeit a different circumstances.
When web broadcast is enabled, it causes CAN communication dropouts. This dropouts result in CAN communication error on the inverter and the power goes off momentarily. This started when I updated to build 51.
However, with build 54, there is a new problem. When the power goes off and back on, the Wi-Fi disappears and the toolkit software goes offline until I restart the watchmon core. I have to disable web broadcast to make it work properly.
