Hi team. A quick question I think. It’s possible to remove or cut a bit of a metalized part of blocksmons?? Please see attached.
Hi Jetro.
We don’t recommend modifying the BlockMon as they are very easily damaged and will not be covered under warranty.
Flexing the PCB or bumping any of the nearby components will damage the module. This part of the PCB has no circuit trackwork beneath it and so in theory, yes.
We suggest that if you have a limited mechanical area to work with, we recommend you adopt the CellMate-K9. It is our new centralised cell monitor CellMate-K9, which allows for 3s-16s connection.
