Where can I find it?
Hi! @roy.nathan
The Manual Extract Report gives us an overview of the configuration you are using so we can see if there is anything in the setup that might be causing the error.
1. Navigate to Tool menu.
2. Go to “Snapshot Report” button.
3. Press “Extract” to generate report.
4. Open the folder.
5. The latest “Snapshot…setup.txt” file (the file you just generated) is the Manual Extract Report.
This is the complete report. Notice that the file size is larger than the regular automated reports in the same folder.
