K9 only seeing 2 temperature sensors
I have a new installation, nominal 24v (8 x MB56 LifePo4)
I have installed all 4 temperature probes from the Cellmon K9 but the telemetry is only reading probes 1 and 2, warming them probe 1 is being attributed to cells 1-4 and probes 2 to cells 5-8.
I have searched everywhere, this wiki, manuals etc for a config setting for this but cant find anything referencing it.
Im running 2.17.57.0 which shows as the latest version.
Everything else is working very well, Victron Integration passes the average of temp probes 1 and 2 but again ignores probes 3 and 4.
Advice anyone?
Ric
Hi Ric,
Thanks for reaching out!
We will indeed attribute each temperature sensor to two cells if you have configured things correctly.
Could you please private/direct message me your serial number, and provision your device, and I will take a look:
Keen to get this sorted for you!
Thank you James
I will get the serial number to you probably later this weekend.
Ric
Did you get my DM? I think I did it correctly?
Hi Ric,
DM recieved.
Try turning off the “different nominal series” setting:
You do not have multiple banks, so your total number of cells is the same as your nominal series, so no need for that setting to be on.
