Hi Batrium-Team, i experienced a strange behavior with one of my longmons. This is the first time my battery gets full, so they started bypassing. One longmon have weird voltage readings while it is bypassing. On first time bypass test after installation with your software assistant there was no problem so far. Now it is toggling very fast and a bypass test failed. I recheck both battery connection these are ok, my screws are all set with specific torque, I disconnect the supervisor and the longmon for some time, to give it a fresh boot. But this does not change its behavior. I added a small gif file (screen record) to show you the behavior. Can you give me any advises to fix the issue or need it replaced?
