Fronius GEN24 Plus whit Batrium
I have big plan to future, plan is Fronius GEN24 Plus 10kW inverters put work to home whit solar panels and want put battery system to it, problems is at manual say BYD,LG and Fronius own battery is supported but can get Batrium get “talk” whit this inverter?
Reason is make own battery system can get big capacity same price.
I not know can get work together that why want ask at anyone has any mind to fo them talk together.
Battery size plan is 128x 3.2v 314Ah EVE MB31 LiFePO4.
Its just in plan now so and plan always van change, there is list what Inverter Batrium works direct?
Because i just think at another what can use is SOLIS HYBRID INVERTER S6-EH3P20K-H-EU if it can get work.
I would recommend using Fronius. It is a very efficient hybrid inverter, also in low power area. And it completely respects the limits of the BMS. I have the Deye SG01HP3 and I have a lot of problems because they have problems in respecting 0A max charging/discharging currents.
e.g. charging 0A leads to a 0,5A charging process that does not stop until charge voltage is reached. When 0A discharge is sent, it still consumes 100W out of the battery when there is currently no PV surplus available.
The GoodWe ET hybrid inverter respects the targets, but it has safety issues. For example, if a person with bluetooth and the app of GoodWe is near the inverter it can completely have remote control of your inverter. If this is no problem for you, then you can also select this one. But from efficiency topics, the Fronius is currently one of the best inverters and works with BYD protocol without any problems.
You can also have a look here: https://solar.htw-berlin.de/studien/stromspeicher-inspektion-2025/
And if you have problems with the implemented Batrium protocol you can take this emulator and just set the native 2.0 protocol at Batrium: https://github.com/dalathegreat/Battery-Emulator/tree/main
I read wiki in hire and all other and i understand now at Fronius can talk whit Batrium like its look LG or BYD, this help me much plan system more.
I do not know if it is still a topic for you with the hybrid inverter. I would recommend you to use the new Fronius Verto Plus because it has a 50A battery input. The Sumo Gen24 Plus only has a battery current of 22A which is not so much when you have a nominal voltage of 409V. What is your overall PV input power of your home?
True, that i change plan allready when i find this new model but its still in plan. PV i not undestand but house has 3x35A main fuse.
