Expansion with additional blocks
Hi, I have a WatchMon Core with BlockMon for four blocks. Now I want to add two more blocks and need help doing so. What do I need to do and in what order? The hardware cabling is complete.
Thank you for your help.
Hi Speiler,
I would suggest following these steps:
  1. Make sure your software and firmware are up to date:
  1. Run through the Wizard Setup to set all values correctly for your new number of cells:
  1. Run a Device Sync to ensure the BlockMons are connected and configured correctly:
Please let me know if you have any troubles during this process :slight_smile:
