At this moment, there is only one cooling parameter that can be selected for activating a fan.
Is it possible to differentiate between cooling of cells and cooling of bypass?
Hi John,
They currently operate on two control loops:
- “Cooling Required” expansion option is triggered by the Control > Thermal tab
- “Bypass fan prolonged” is triggered any time bypass starts, and runs for a short while after bypass has finished to dissipate the remaining heat.
So as long as you set one output to one, and one to another, you’re OK ![]()
Thanks,
I have set the bypass cooling to a separate output of the expansion board.
JOhn
