Buenos días, después de instalar la ultima version 54 con su firmware correspondiente satisfactoriamente el programa arranca como si no estuviese configurado.
he intentado volver a la version anterior que funcionaba sin ningún problema, que era la 2.17.27 con su firmware correspondiente, pero la pantalla muestra los datos erroneos como si no estuviese configurado, de hecho no lo están pero no hay manera de que acepte el pin.
Después de contactar con el servicio técnico.
Parece un problema que puede suceder a partir de la version 47
Problema solucionado, después de restablecer la unidad con un código facilitado por el servicio técnico, la Watchmon core funciona nuevamente.
Un Saludo
Hi Everyone else,
Here is Jose’s posts translated:
Good morning, after successfully installing the latest version 54 with its corresponding firmware, the program starts as if it were not configured.
I have tried to go back to the previous version that worked without any problem, which was 2.17.27 with its corresponding firmware, but the screen shows the wrong data as if it were not configured, in fact it is not but there is no way to accept the pin.
After contacting technical service.
It seems like a problem that can happen from version 47 onwards.
Problem solved, after resetting the unit with a code provided by technical service, the Watchmon core works again.
All the best
Just for future reference, we prefer posts in english, so make sure you run things through google translate first
All the best with your projects!
