I use the relay A “Critical BattOk” for release my load-break switch.
Now I have the problem, when the SoC gets re-calibrated, my load-break switch
open the connection and takes the batterie from the system.
I remember, in the beginning I don´t have this issue.
Which firmware version are you on, and what are your recalibration values? If you set the value to small (i.e. 100.5) then it can do this too frequently and lock up the processor. Our default value of 101.5 will not do this.
