Hello all, I’m curious to see if anyone else is running tesla packs and cellmates. The modules were perfectly balanced prior to using them with the cellmates . Many charge and discharge cycles without balancing. Now that I’ve had the system hooked up running for about a year with cellmates and watchmon core that the cells are more out of balance than they were without bms balancer. Not a huge gap let’s say 4.06-4.02 but regardless it seems the balancing bypass function is making it worse .
Has anyone experienced this ? The cells are 2018 model s . I would hate for the cellmate to make the cells drift further if I were to ignore the problem.
Cheers!
