BMS Settings for EVE LF280K 16S
I am using the same setting to limit the charge voltage.
That’s right, we are currently doing testing in-house on this and will have a release soon.
I suggest sticking to standard CC/CV control until that point (no DVCC)
Thanks James, I’ll turn DVCC back off. As you can see all my settings in the posts above, is my voltage charge ok ? I’m using the Batrium defaults for Longlife LifePO4 so assume they must be ok.
Simon.
Hi Simat,
Yep, they should be OK, I can see kleini’s comments regarding cell voltages, and it is certainly true that holding cells at high voltages shortens their life for little capacity gain, hence our LongLife preset being a lot lower than cell manufacturers say is the max.
The important thing is to make sure that your cell voltages remain in the same order as the defaults. Feel free to run any changes past us.
