I have a setup with 16pc Eve LF280K and cellmate k9.
Now with sunny days, my battery is full. But I see a strange behaviour at the voltages.
All uneven cells are at 3.5V, the even cells are between 3.51 and 3.53.
Just curious why this is.
John
John
Hi John,
Thank you for adopting BMI, I’ve been able to take a look at your system from here and have a few things I’d like you to check.
A new, healthy system should be doing <50mAh of balancing a day, yours is doing as much as 1200mAh
Please let me know if you need me to clarify anything above, I’m more than happy to explain further
Thanks.
I am not able to make changes on short notice.
This weekend I will very and adjust as recommended and let you know.
John
James, I have just set the values to the default settings as recommended. Do uiu have any recommendations on the Victron Assistant settings, based on the default Batrium settings?
